Płukanie Spark
MIt
Zgodnie z instrukcja Sea Doo to silnik nie powinien chodzic dluzej niz 2 minuty:
Warm up the engine following the exhaust flushing instructions found in your operator’s guide. Remember, never run your engine without supplying water to the exhaust system and never run it for more than 2 minutes at a time. Repeat the engine warm-up process twice, letting the drive shaft cool down for 5 minutes between each cycle.
Run the engine for 10 seconds at 4,000 RPM and shut it off at this RPM by pulling the tether cord. This will move oil from the PTO housing to the oil tank to allow maximum oil draining.
czynnosc poworzyc po 5 minutach przerwy.
