Kabel adapter z mercury mercruiser quicksilver 84-896541T01
wojtas75
Do przedania kabel adapter jak w tytule.
MERCURY BOAT KEY SWITCH HARNESS 84-896541T01 | TRACKER 3 FT
Boat part number 8102593 is a new boat harness assembly / key switch adapter from Mercury Marine / Mercruiser / Quicksilver, part number 84-896541T01 .
Boat part number 8102593 is a new boat harness assembly / key switch adapter from Mercury Marine / Mercruiser / Quicksilver, part number 84-896541T01 . Commonly used on Tracker Marine Boats, part number 129735 . May be used on other boats.
This boat harness assembly / key switch adapter allows you to connect a 14-Pin Female boat harness to the 8-Pin Female engine connection. Measures approximately 3' Long overall. Harness assembly adapter cable reads, 'MM GPT 1-14 GA / 6-16 GA / 5-18 GA MARINE WIRE SAE J378 J1128 60V DC 105 degrees C'. Mercury Marine produces the Quicksilver line of parts. Quicksilver parts are made for use on Mercury, Mariner, MerCruiser and Force engines. In addition, they cover many applications by the following engine manufacturers: Chris-Craft, Chrysler, Crusader, Evinrude, Johnson, Honda, OMC, PCM, Suzuki, Volvo Penta, and Yamaha.
Specifications:
Boat Manufacturer: Tracker Marine
Part Number: 129735
Manufacturer: Mercury Marine / Mercruiser / Quicksilver
Part Number: 84-896541T01
UPC: 745061688490
Materials: Marine Plastic / PVC Cable / Copper Wire
Colors: Black
Overall Dimensions: 3' Long
Connections: (1) 14-Pin Female Plug / (1) 8-Pin Female Plug / (4) Wire Ends
400 zl
Tel 504556610
https://www.olx.pl/oferta/kabel-adapter-z-mercury-mercruiser-quicksilver-CID767-IDIQ3uM.html
